Pilot Faces Prison For Falsifying Medical Application
The Transportation Security Administration (TSA) reported yesterday that a federal jury has convicted a pilot of twice making false statements to the Federal Aviation Administration (FAA) on his application for a Class 1 medical certificate. The case, dating back to June, involves pilot Olukayode Ojo, 36, of Dallas, Texas. Ojo was found guilty on August 16 on two counts of making false statements.
This is a companion discussion topic for the original entry at https://www.avweb.com/uncategorized/dallas-pilot-made-false-statements-on-faa-class-1-medical-application
Something here doesn’t pass the smell test. Misdemeanor convictions stopping someone from a decent career needs explanation and details. Is this a fair and reasonable assessment? If we’re to debate the cons and merits of this situation then more needs to be told.
Agreed WRT the merits of the system - it seems petty that minor offences would prohibit a Class 1 Medical (I have no idea of the actual regulation), but, like many minor infractions that blow up to be major - it’s the cover-up not the actual initial infraction that causes the issue.
I’ll bet these offenses indicate a person not having good moral character.
Why is the TSA releasing information that is under the responsibility of FAA Aeromedical? Is the TSA going to be used to make criminal convictions of FAR violations?
We had a similar statement in our employment applications. I’ve hired people with many, many different problems and pasts. From minor driving incidents, to multiple felonies. But mark ā€œno prior convictionsā€ and have any kind of record? You are out of here so fast you’ll miss the door going by as you sail through it. It’s not about what you did. It’s that you lied about having done it. Seems the same issue is true here.
The guy should have said something about it–They look at medical information as telling the truth, not so much as what he’s done. Heck, the guy was probably a sniffer and took a chance that there might be some dirty underwear in there. Typical pilot. To qualify as a captain in the old days you had to have one divorce, two arrest (no convictions) or you might not make the check out program!
Tom - I’m sure that the FAA concern is the falsification - and if he was convicted of a crime, and didn’t disclose it, he was clearly aware of the falsification.
I would assume that the TSA was part of the trial to convict him on theft from luggage. I also would assume that TSA was ā€œmore than helpfulā€ in contacting the FAA to follow up on the matter.
Because the TSA is responsible for identifying and investigating security and safety threats. In this case, Mr. Ojo fits that bill. For sure though, the FAA will take certificate action as well.
It’s all about the lies on applications, not what the lies were for. Do not lie on an application. It probably even states what the penalty for doing so is.
Look on the bright side … likely to have plenty of time to get fit enough to sail through the medical when he gets out…
My question has always been, why does the medical application ask about prior convictions? Unless they are for substance abuse, they really shouldn’t belong on the medical application form at all. Certainly they should be questions on job application forms, but not the medical application form.
Lie about this, lie about that.
You cannot trust liars.
The medical application is often the most recent contact the FAA has with a pilot. Like it or not, it’s their ballgame.
Unstated circumstances are likely behind what looks like the use of his lying on the medical application as a convenient ā€œhandleā€ to remove Mr. Ojo from the playing field. Utilizing an easily prosecuted offense that may be only indirectly related to the prosecutors’ underlying motivation is a shortcut used all the time in the legal system. Many people may feel concerned about this, but right or wrong it is certainly ā€˜legal’.
The real question is if brushes with the law should even be considered relevant information to include in the process of declaring a person medically capable to safely fly an aircraft. Entwining unrelated objectives into a process that presumably is intended purely as an evaluation of medical fitness seems to be a bad idea.
TSA must be communicating with the FAA better than other law enforcement with automotive DUI(s) sometimes not reaching FAA awareness.
One Observation…a Medical Certificate should be on the subject of Medical topics…general physical heath, mental health, and subsequent risk for flight safety. this should not be in any way shape of form a screening for criminal past. THAT should be at the depression of the employer. This is NOT an application for a secret clearance.
The medical is the only piece of the pilot certification system that expires regularly, so it’s used as a mechanism for the FAA to catch up on ā€œwhat have you done lately?ā€ It is kind of screwy that they put that non-medical stuff on the medical application, but I’d much rather have the current arrangement than have pilot certificates expire every two years.
