Why a Narrow Radar Beam Is the Smarter Choice for Seaplanes
For seaplane pilots, the transition from air to water is the most critical phase of flight. When the water turns to a mirror and your depth perception vanishes, you rely on your instruments to tell you exactly where the surface is.
But not all radar altimeters are created equal. In the world of LiDAR and RADAR, there is a technical tug-of-war between Wide Field of View (FoV) and Narrow Field of View. While a wide beam might sound “bigger and better,” for a pilot sitting in a cockpit with floats and struts beneath them, shorter is actually smarter.
It Doesn’t “See” Your Floats
A wide-angle radar sends out a massive cone of energy. The problem? That cone is so wide it often hits your own floats, spreader bars, or landing gear**.** When the radar hits your plane instead of the water, it gets confused. It might tell you “Zero Feet” while you’re still 20 feet up.
A focused 45° angle, like the one engineered into the SkyVoice Glassy Guide, acts more like a high-intensity spotlight. It ignores the distractions to the side and focuses purely on the distance between your hull and the water.
Reasons a Shorter Angle (45°) Wins Every Time
1. Eliminating “Ghost” Returns
A wider beam is much more likely to “catch” a piece of your own aircraft. If the radar signal bounces off a float or a landing gear strut before it hits the water, the device can provide a “false floor” reading. A 45° field of view stays tucked safely between your floats, ensuring that the only altitude you hear is the true distance to the wet stuff.
2. Superior Performance on Glassy Water
Wide-angle sensors disperse their energy over a massive area. On glassy water—which acts like a mirror—that energy can scatter, leading to “signal dropouts.” The SkyVoice Glassy Guide 45° beam concentrates that energy into a tighter footprint, providing a stronger, more reliable “echo” back to the sensor. This means smoother, uninterrupted height announcements exactly when you need them most.
3. Stress-Free Installation
Finding a mounting location for a wide-angle sensor is a headache. You have to stay far away from landing gear, antennas, and steps to keep the “view” clear. Because the SkyVoice beam is precise, it needs a much smaller “window” to look through. This gives you more flexibility on where to install it without worrying about interference.
Why SkyVoice Glassy Guide is the Pilot’s Choice
The SkyVoice Glassy Guide 400 was designed for the rugged, complex underside of a seaplane. By utilizing a 45° Field of View, we provide:
Precision Accuracy: Reliable callouts from 400 to the 1 foot, even on the calmest water.
Reduced Interference: Less chance of the radar “locking onto” your own floats or waves.
Audio Integration: Clear, real-time height announcements that allow you to keep your eyes outside the cockpit where they belong.
When you’re 20 feet off the surface and the water is like a sheet of glass, you don’t want a sensor that’s looking at your floats. You want a sensor that’s looking at the water. That’s the SkyVoice advantage.
