Pilots and controllers rely on each other to communicate unambiguously, especially when working together to complete an instrument approach. The rules of the game are supposed to be clear, yet somehow pilots and controllers continue to clash when an aircraft is in position to join the final approach course straight-in without flying a published procedure-turn holding pattern. Are you being vectored or should you fly the hold entry?There has apparently been so much confusion in this area that AOPA Air Safety Foundation created an online safety course devoted to unlocking the mystery. The course, "IFR Chart Challenge: VOR Approach," describes an incident that occurred on the VOR approach to Runway 34 at the Carroll County Regional Airport in Westminster, Md., (DMW). The aircraft, a Cessna 182, was located southwest of the airport approaching the Westminster VOR (EMI) and had been cleared for the approach. The Potomac Approach controller issued the following instruction: "Cessna 611MS, 10 miles from Westminster. Proceed direct Westminster, maintain 3000 until established. Cleared VOR Runway 34 approach Westminster." At the time, the aircraft was located on the 190-degree radial, 10 miles southwest of EMI, heading 010 degrees at 3000 feet.
This is a companion discussion topic for the original entry at https://www.avweb.com/flight-safety/vague-vectors
