True Blue Introduces GA Lithium Batteries - AVweb
True Blue Power unveiled two new lithium ion batteries for general aviation aircraft Monday at the 2013 National Business Aviation Association convention in Las Vegas. The Wichita-based company, which is a subsidiary of Mid-Continent Instruments and Avionics, introduced ship's power batteries aimed at both the twin business jet market and the turboprop and piston single segments. CEO Todd Winter said the batteries, which are rated at 44 ampere hours and 17 ampere hours respectively, are much lighter and require less maintenance than lead acid or nickel cadmium batteries. Although they cost more initially than the other types, the reduced maintenance and relative longevity of the lithium ion batteries make them less expensive in the long run, Winter said. They also offer some significant performance advantages, including more starting power and quick recharge. The big battery will charge from flat to fully energized in 15 minutes. "Pretty much by the time you're off the runway, you're at full emergency backup power," he said. The higher energy density brings some increased hazards but Brett Williams, who heads up the engineering team that designed the batteries, said built-in safeguards will prevent any sort of battery malfunction from damaging the aircraft.
This is a companion discussion topic for the original entry at https://www.avweb.com/news/true-blue-introduces-ga-lithium-batteries
