Texas Airport Weighs $500 Self-Fueling Permit
Originally published at: Texas Airport Weighs $500 Self-Fueling Permit
Proposed fees would affect pilots bringing outside fuel onto airport property, including mogas and unleaded avgas.
It’s amazing how many schemes airport operators come up with to charge fees! I would prefer to pay an FBO for mogas or unleaded avgas if it was available. Unless hangar or tie-down fees are really cheap, all this will do is drive owners to go somewhere else.
This shows just how worthless the EAGLE initiative really is. They should’ve already provided a pathway to get as much unleaded fuel of any type on the airport at a convenient location and provided dispensing structure support that would result in the cheapest possible price for unleaded fuels at the airport.
So a private owner is being held to the same standards as a commercial operator specifically when the airport doesn’t provide a product or service the private owner needs or wants. Amazing. Most of these idiots running these airports and members of these advisory boards aren’t pilots and if they are, it’s more than likely they have a rating but no real experience or worse, they have just retired from the airlines and are starting to stick their feet into GA. Additionally, most of them are have never owned a business or know how one actually operates so they feel that hitting everyone with with insane fees is a good thing. The FAA doesn’t give a rip as they just defer your complaints this practice right back to the idiots running this circus for the county. Check out the bs here in NC. This type of structure is killing aviation in NC as well as in many other locations across the USA and it seems that all our voices concerning insane practices and fees imposed by the local governments is falling on deaf ears.
The answer to this whole shemozzle is a universal drop in unleaded fuel;
No STC’s or other nonsense.
IF the FAA and such as AOPA were serious, we would already have this.
Scandinavia has had high octane unleaded for years; better for engines.
GAMI is approved;
If the big fuel companies don’t want to give up their profitable AvGas business; too bad
They are the drivers behind the endless delays.
Unleaded fuel is better for engines; despite nonsensical myths!
Get this done so we can all move on.
So are they going to inspect everyone’s vehicles for 5 gallon gas cans of MO gas? Will they put cameras in everyone’s hangers to monitor what goes on behind the hanger doors? If they pursue this approach - which it sounds like FAA regs may prohibit - then they should at least exempt the “hobby” pilots.
“The answer to this whole shemozzle is a universal drop in unleaded fuel”
That would probably depend on the cost of a universal drop in unleaded fuel.
What’s the price delta of a universal drop in unleaded fuel vs the mogas available at my local Sheetz or marina?
What is the price of AvGas these days?
A drop in fuel would own the market; could likely be price similar.
One of the aircraft I fly has a 91/96 engine perfectly happy on Mogas; no STC.
Another is an 80/87 engine; no STC.
A third has the original plate on the (vintage) engine explicitly banning lead in the fuel. (uses Mogas without an STC)
A fourth uses Mogas under a “Blanket Exemption”; albeit with slight restrictions.
IF there were serious non political/non status quo protective parties,
We would already have a drop-in fuel for all aircraft.
One field I operate from has a triple tank system; 100LL, Mogas, Jet A1
The minimum we need is unleaded 100, so we can all move on!
If priced similar, my local avgas is $6.75.
Mogas is $4.79
At that delta, I’d still truck my own gas in.
Mogas is great, if there is an approval.
For the rest of the community, we need a drop in 100 fuel with no STC’s etc!
Well, do fuelling safely including type of container and grounding.
But the airport is being _____ !
Well, mogas without ethanol.
Is GAMI’s STC that expensive?
No fees to bring in your own fuel. End this nonsensical push to get rid of 100LL. It (lead) is not a problem.
Lead can definitely be an issue. I (stupidly) take very little precautions when dealing with 100LL. My blood levels are elevated, but not clinically significant. I routinely have it on my bare skin nearly every day. If we can get rid of it, great. Until then we are just stuck for the higher output engines.
The real issue here idms whether or not the airport authorities are trying to unreasonably prohibit individual owner/operators from refueling their own aircraft with their own fuel. That will get real sticky really quickly.
