Stop Fighting the Audio Panel. Start Hearing Your Alerts
You are faced with the classic aviation “bottleneck.” You want to install great new safety products, but the “gatekeeper”—the audio panel—makes the upgrade too expensive, too risky, or too complex.
The Solution is Here. Introducing the Stack-Pass MixAmp, the FAA-approved speaker solution from Holy Micro! as part of the Absolute AoA system. By creating an independent audio path, we have bypassed the most painful and expensive part of avionics installation. It is a panel-free audio integrator that provides total independence from the center stack.
“Installing modern safety tech shouldn’t require $5,000 ‘center stack’ surgery,” says Frank Kunnumpurath of Holy Micro! “Our new Stack-Pass MixAmp is designed to bypass the complexities of existing audio panels, saving you thousands in installation costs while guaranteeing you never miss a critical alert.”
The Problem: The “Audio Bottleneck”
Most pilots face three major hurdles when adding new gear:
  1. No Room: Existing audio panels are often “maxed out” with no open ports.
  2. Audio Drowning: Critical alerts get muted or overpowered by busy ATC or CTAF chatter.
  3. High Risk/Cost: Opening a decades-old center stack is a “can of worms.” Most technicians are hesitant to touch them, and specialized avionics shops charge premium rates just for the labor.
The Solution: The Holy Micro Independent Audio Path
Our FAA-approved, aviation-grade Voice Range speaker—complete with a mixer-amp-driver board—provides a dedicated, high-resolution audio environment for your Absolute AoA and SkyVoice products without ever touching your existing audio panel.
  • Zero Stack Interference: No need to disturb your GPS, transponder, or radio wiring. If your A&P can run a power wire, they can install this system. Your primary COM and NAV audio remain untouched, giving you high-fidelity auxiliary audio without compromising your primary lifeline.
  • 3-Channel Smart Mixing: Connect up to three audio sources (two wired and one Bluetooth). Hear your Absolute AoA tones and SkyVoice announcements mixed perfectly in real-time—a feature no other product on the market offers. Once secured behind the panel, you can easily manage pairing, mixing, and volume remotely using any smart device or the Holy Micro HMI.
  • Guaranteed Audibility: Our high-grade aviation speaker is designed to penetrate even the most advanced noise-canceling headsets. Experience crystal-clear audio layering without the “mud.”
  • Massive Cost Savings: By simplifying the install to a basic electrical task, you save thousands in specialized avionics labor and avoid significant shop delays.
  • Versatile Integration: Prefer your headset? Use the board as a “pre-mixer” to combine three signals into one single, un-muted input on your existing audio panel.
The Bottom Line
You get the lifesaving safety of Absolute AoA and SkyVoice alerts with a “no-surprises” installation. It’s cleaner, louder, and significantly more affordable.
Upgrade your cockpit today for just $585.
Stop Fighting the Audio Panel. Start Hearing The Alerts.
