Soloy Receives FAA Certification For Turbine Cessna 206
Soloy Aviation Solutions, of Olympia, Wash., received FAA certification on Oct. 28 for its Soloy 206 Turbine Mk II, a turbine version of the piston-powered Cessna 206H. Powered by the Rolls Royce 250-B17F/2 turbine engine, the Mk II provides an increase of 110 hp over the standard Cessna 206H, Soloy said this week. With the turbine conversion paired with a Hartzell three-bladed prop, the airplane can carry more weight, fly faster and operate in high and hot conditions. The performance also improves the airplane's STOL performance, especially in its amphibious configuration, Soloy said. "The Mk II is the perfect platform for vast number of applications, from law enforcement to adventurous backcountry operations," said Dave Stauffer, president of Soloy Aviation Solutions. "The lighter turbine engine increases the power while reducing the basic empty weight by approximately 150 pounds."
This is a companion discussion topic for the original entry at https://www.avweb.com/news/soloy-receives-faa-certification-for-turbine-cessna-206
