With the parachute armed, the engine run-up accomplished, our departure time is here. I use the coolie hat atop the side yoke to set a bit of nose-up trim, center the aileron trim, and check that the separate rudder trim is also neutral.
This is a companion discussion topic for the original entry at https://www.avweb.com/ownership/smokin-cousin-the-cirrus-sr22
