Safety is Built In, Not Assumed: Keeping Collision Avoidance Ahead of the Traffic
Originally published at: Safety is Built In, Not Assumed: Keeping Collision Avoidance Ahead of the Traffic
Combining TCAS and ADS-B In can give pilots more time to prevent midair collisions.
ADS-B is not a collision avoidance system and was not designed as one. It is a traffic advisory system. TCAS is a certified collision avoidance system. The issue is certification and cost. If you want to install a TCAS on your plane, go for it. Top and bottom antennae, certified boxes and transponders, etc. Also, TCAS operates on 1090 Mhz, and having all aircraft interrogating on 1090 Mhz, in addition to many ADS-B transmissions, will overwhelm the frequency. And then there are the UAT ADS-B folks that are on a different frequency.
This was considered when the FAA was moving towards ADS-B. The FAA’s decision was likely a good one. It allows relatively low-cost ADS-B boxes for traffic advisories for smaller aircraft and requires TCAS for larger passenger aircraft. If you want TCAS for your smaller aircraft, go find a vendor–it is allowed.
Best
Vince
Cam, your NGT9000 is a fantastic unit. It lives right below the audio panel in my Deb. While I have ADS-B “in” on my iPad, it’s great to have the traffic display on the NGT9000 always at 2nm.
However, the NGT9000 is no longer priced appropriately, the requirement to re-purchase enablements when purchased used, and the $5k flat rate repair cost are keeping you from the market that the unit deserves. Now, with the Sky Hound, the market continues to shrink.
I realize that you guys are looking at the huge ADS-B “IN” opportunity on the airlines right now, but the NGT-9000, if it was priced similarly to the GTX345, would really get a lot more (well-deserved) attention.
