In a report long on probablies and possibles, the Director of National Intelligence said this week that dozens of sightings of unidentified aerial phenomenon have no plausible explanation but do represent a threat to flight safety and national security. “Most of the UAP reported probably do represent physical objects given that a majority of UAP were registered across multiple sensors, to include radar, infrared, electro-optical, weapon seekers, and visual observation,” the report said in an executive summary. Although sighting data seemed to be accurate and credible, the available reporting was “largely inconclusive.”
If it’s really Aliens - I’m pretty sure they have some kind of decent “See and Avoid / Deconflicting” technology that will work 99.99999% of the time. The other 0.000001% is some unexplained crash that the NTSB/FAA might probable cause as “possible CO poisoning”.
Me - I’m sticking with my conspiracy theory that this is a “Glomar Explorer” type story. For younger readers - a ship that was touted as mining for precious metal nodules from the seabed - actually cover for a ship that was trying to raise a sunken Russian submarine - look it up - even the Reader’s Digest covered it.
This “report” and the credible witnesses interviewed on 60 Minutes, is cover for something we have, that we need to keep under wraps from the inevitable sightings and leaks.
144 government reports, 80 with multiple sensors is quite convincing. I am all in. I want one.
We have changed the name from UFO to UAP presumably to be more inclusive and not hurt the feelings of the ET’s. After all who would want to be called an Object! UAP is a softer gentler version of UFO. UAP doesn’t give me nightmares and flashbacks to dead aliens at Roswell. I woke this morning feeling better that their was no longer UFO’s.
Many of the 144 government reports have the UAP (PC version of UFO) operating into and out of the oceans. To be inclusive, and not slight our naval friends, we must rename the phenomenon USP (Unidentified Sea Phenomenon) as the unidentified transition from air to water. To simplify the process, because they are no longer objects plus transition in an out of the water really fast, we should rename the combo USAP.
Correct me if I am wrong but isn’t MAN the second syllable of AIRMAN? Isn’t MAN the second syllable of WOMAN as well! Now comes the same government that invented UAP telling us that MAN in AIRMAN is offensive. Hence the reason You-SAP makes more sense. Perhaps it is time to reach out to the ET’s for help before we destroy ourselves?
UFO - Unidentified Flying Object - implies that it is a physical object. UAP - Unidentified Aerial Phenomenon - doesn’t make such an assumption and doesn’t rule out that it could be a sensor glitch or misperception. It also doesn’t imply that the “whatever” is “flying” (that is, using aerodynamics in some controlled fashion). There’s nothing “PC” about UFOs being renamed UAPs.
Also, I think part of the reason for renaming them is that UFOs have a certain connotation (that’s it’s “aliens” or a hoax) that makes it hard to seriously investigate the reports.
Graeme Smith is correct. I am certain that ET’s have something more advanced than TCAS. Doesn’t even require the OTHER Flying Object/Aerial Phenomenon to have a transponder… Another “the sky is falling” statement from government hacks who think they can repeal the Law’s of Physics if they have enough judges on the Supreme Court… I also agree that there is at least a 50/50 chance that MOST of not all of these seemingly legitimately, conclusively, REAL Objects/Phenomenon are OURS, and it is another DENIAL from the gov’t like there was in the beginning with the F-117…
Hello Gary B., Sensor glitch’s, misperceptions, and don’t forget about swamp gas. Swamp gas is tricky and will fool us every time. The crazy stuff can move at Mach speeds and change directions in the blink of an eye too. Some nasty stuff for sure.
Hello Gary W. Sarcasm circuit breaker reset. Check.
I am really pleased to see swamp gas mentioned. For many years we only had two official explanations - weather balloons and swamp gas. Then swamp gas seemed to fall out of favor. Glad it is back, and clearly as plausible as aerial clutter and Tic Tacs. Now if we could just get a handle on all those mysterious abductions.
