Pilot Poaching Domino Threatens Recovery - AVweb
As travel numbers continue to climb in the U.S., airlines are poaching pilots from countries where the recovery is lagging in a domino scenario that could seriously threaten the aviation recovery in some places. Australian officials say they’re worried a recruiting drive by U.S. airlines in their country will hamstring the industry when its pandemic recovery finally begins. Australia still has strict travel restrictions in effect and flight schedules are at about 25 percent of pre-COVID-19 level while the U.S. rate is about 80 percent.
This is a companion discussion topic for the original entry at https://www.avweb.com/aviation-news/pilot-poaching-domino-threatens-recovery
I had the opportunity to visit the London, Ontario factory on several occasions about twelve years ago when they were going gang busters building 20’s and 40’s. You can’t imagine how well built these aircraft are until you actually see it. The whole operation top down is very impressive, or, at least it was way back when. The people couldn’t be more friendly and accommodating. I don’t know how it its now, but, ten twelve years ago I had no problem getting a factory tour just about any time I wanted. If anyone is able, I strongly suggest calling up Diamond or e mailing them to try to get a tour of the facility. Even if you do not fly a Diamond, it is definitely worth your while. My bet is, if you have ever been on the fence regarding a Diamond aircraft, you won’t be after the tour.
Good video, Paul. If anyone wonders why composit aircraft have not totally replaced all-metal designs, the tremendous amount of hand labor involved is obvious here. Plus the huge amount of waste material generated in the vacuum bagging process is obvious. The electronic quality checking of the avionics wiring layup is very impressive so that the finished wiring loom should be trouble free.
While composit construction is labor intensive, the video demonstrates how it enables both the sleek, aerodynamic design, as well as the high strength of the wings and how they safely incorporate the sealed and welded aluminum fuel tanks. Overall, an excellent factory tour. Hope to do one in person some day.
Outstanding job!
Interestingly, the principles of composite construction seem to have changed little from the '70s and '80s when we laid up whitewater kayaks by hand. What is truly breathtaking is the level of automation Diamond has brought to the process.
As other commenters have stated, a first class operation from start to finish.
You want to see something impressive, you should see Diamond’s CNC machine. It is huge and very impressive. I forgot what it all cut out. I think it was the instrument panels, other misc. parts, pieces and that was 12 years ago. I remember it cutting some really thick stuff like 3/8” and 1/2.”
Kim, unfortunately you are correct; little has changed in the actual layup of parts. The initial cutting and pre-preg process is more automated, but the final bagging process is pretty much unchanged. One thing that stands out with composit construction is the requirement for strict cleanliness standards. Any airborne dust can quickly contaminate the molds, leading to ruined parts. No amount of preparation for painting will cover over a grainy surface. The impeccable paint we see in their finished aircraft demonstrate their attention to cleanliness in the manufacturing process.
Great Video. Your animation rocks! Thanks Paul.
Great Video. I’m now looking at Diamond used prices!
I enjoyed the video showcasing the build of a Diamond aircraft. An average for Diamond is 2500-3500 man-hours to build and deliver an airplane depending on single or twin. Cirrus build times are similar at 2800 man hours averages for their piston single aircraft. It has taken Diamond and Cirrus decades to get to this level of efficiency ( depending on one’s definition of what efficient really is) of hand-built aircraft. Diamond stated 23 man-hours to complete a Garmin panel, less wiring, and air-frame installation. There were lots of work stations dedicated just to build the wiring harnesses from start to tested finish. They did not say how many man-hours that entire process took. I suspect 150-200 man-hours total would be reasonably normal. But they did track percentages of efficiency as it related to each work station throughout the hand-crafted build.
Looking at what Diamond has to do in body work on a completed air-frame is still, good old-fashion grunt body work that accounts for 100’s of man-hours to putty, block-sand, primer fill , static prime, and then hand-shoot the paint. None of the video showed the layout work required for a three color paint scheme, and the paint shooting sequence to complete the paint job. This is why custom car builds are six figures. An airplane has two to three times the surface area of an average car. That is why an average used single engine airplane costs $15K-35K at a refurbishment shop. Having experience in painting both Cirrus and Diamond Aircraft, $26-40K is the norm because of certified paint process required which in the case of both Diamond and Cirrus are proprietary blends plus the chemical/type data required sequence to strip and re-paint just as is done at the factory when new. If not adhered to in all phases of refurbishment, the airplane does not meet type data specs and therefor is not legally airworthy. Having the local PMI/FSDO/OEM lawyer get involved debating the airworthiness of the refurbed airplane makes for some interesting dialogue.
This is why the majority of the Cirrus and Diamond certified service centers refuse to strip/repaint, do warranty touch ups, or insurance work. This is why many customers of composite airplanes are stuck in 6-9 months waiting periods for warranty and/or insurance repairs let alone a complete strip and paint. Very few places want to do this. This is another reason why both manufacturers are in the refurbishment business because of the technical/chemical, and man-hour requirements learned in the original manufacturing process that must be adhered to and applied when the air-frames get older requiring refreshing.
Looking at the activity of employees in the background, at all levels shown in the video demonstrates a hand-built airplane at each work station, hand loaded on the rotisseries and jigs with a block and tackle, carefully hand lowered, picked up or turned. Many were looking at tablets and consulting manuals ( a good thing), with carpets and plastic taped all over the place as one climbs in and out of the airplane to complete the task. No sense of assembly line frenzy, speed, robotic automation because that automation is very limited for airplanes, especially composite airplanes, of which selling 100-400 per type per year is a banner year. Nine layers of composites including the protective peels to build the wing, tail components, and fuselage skins just to get to the vacuum bagging process. All of it hand laid up. Diamond and Cirrus look like a well organized customer assist build center with employees supplying the labor in lieu of the customers actually being there.
I am very impressed with Diamond’s sense of quality, reliability, and craftsmanship. It is clear they have invested heavily in a trained work-force. They have to because composite airplanes are still hand-built, custom aircraft. I too, am surprised that Diamond can deliver such levels of engineering and quality at $500,000 dollars.
The world market for $400,000 - 1 million dollar airplanes is about 800-1000 per year total. Those figures have not changed much since the resurrection of piston singles in the early to mid-90’s. When airplanes sold for modern dollar equivalents of $100K or less, sales were 15-17,000 per year in the late 70’s. Van’s alone has demonstrated those price points with 12,000+ sales and climbing. It takes 12-2000 man-hours to complete an average Van’s kit with total expenses less personal labor at $100K or less, many averaging $60-80K complete including paint by folks who never built anything let alone an airplane. Maybe not Oshkosh Lindy quality but solid, airworthy, well equipped, and appealing airplanes. That suggests that to reach any levels of remotely meaningful economy of scale manufacturing 15-20,000 airplanes per year, a completed airplane must have the performance, style, handling, performance capabilities, automation, and price similar to a Van’s product. Anything costing more and delivering less reduces aircraft sales to our current levels.
It is pure fantasy, as far as I am concerned, that “urban mobility” vehicles, which presently depend heavily on composite construction can gain any economy of scale in manufacturing. Plus, FAA regulations to come will include the present acceptable composite construction the FAA currently has knowledge with. While carbon fiber technology exists that can gain some benefit of automation as demonstrated by Elixir, it is still foreign to the FAA and its understanding of acceptable composite construction throughout the majority of the air-frame. That means more regulation regarding certification testing which is required for any commercial flying machine that can carry more than 50 lbs, human or otherwise. That is not including certification tests of the multiple electric engines, ESC’s, and batteries. It’s one thing to certify a new composite air-frame with an accepted and certified power source such as a Diamond, Cirrus, Windekker, or Epic aircraft has done. And all of those completed certifications were extraordinarily expensive and time consuming. Now add at to that recipe, new power-plant technology.
Uber, Amazon, FedEx,etc., have a relatively naive conception of the expense, time, stamina, and sheer willpower it takes to get through the FAA regulatory certification process. Maybe they think their money and business power will supersede that of a bloated, tax-fed bureaucratic juggernaut like the FAA. If I were a betting man, my money is with the FAA as the stronger. They have an unblemished record so far. Especially for regulations that are getting written, debated, and reviewed as development of new technologies mature or die.
The 3D world of aviation has safety challenges unlike any other mode of transportation. For some reason in our homogenized, uni-sex thinking society, flying machines, particularly those who carry humans, can be developed like a car. Airplanes are definitely not a one size fits all machine. But folks continue to seem to think the problems of flight can be solved by some sort of algorithm.
What recovery? After my last airline flight I had, I have serious doubts. When I connected through ATL to catch an Airbus to my final destination the terminal I departed from was almost empty compared to what I used to see before COVID. Sure the flights are full but very few if any of the planes put in storage have been returned to service. Some of the route clearances I am getting tell me there is still nowhere near 80% of what it was before COVID. When I get a clearance to climb to FL400 as soon as I switch to center when departing south Florida airports in the middle of the afternoon, that tells me the traffic is still nowhere near precovid levels. Airline traffic from my home airport on a Sunday mid morning was almost nonexistent. The tower controller was working both ground and tower frequencies simultaneously. In the past I would only hear that in the middle of the night. I keep hearing about airlines going on a hiring binge for over a year now but have yet to see much more traffic yet. I find it hard to believe the airline training departments are that far behind. If they are it will take years before traffic returns to anything close to precovid levels.
My daughter is a Captain at Horizon. She is also a company sim instructor at Flight Safety. Horizon is hiring as quickly as they can find qualified pilots. The company is now offering large signing bonuses again to compete for pilots in response to other airlines doing the same. The recovery and demand for pilots is very real.
Error alert!
‘Poaching’ is a false claim.
The word is based on ownership - but airlines do not own pilots.
AvWeb is irresponsibly clueless.
FTR, Russ Niles is not pleased with my blunt remark.
Common does not mean appropriate.
The term is anti-business, anti-people.
It works against retention of pilots by obscuring pay and working conditions as key motivators - losing employers can blame someone else.
BTW, isn’t upward mobility in aircraft size thus pay the norm in aviation?
Training of new pilots is of course key, many attempts over the years, some much more capable than others so perhaps some should not have been hired - I saw a big difference riding along on check rides after flight tests in the Herc. A frequent career path was to the third seat in the Herc then was flying school instructor, I wondered about one I observed
Horizon’s upward mobility path is it parent company Alaska Airlines, I presume. (Though at one time much of Horizon’s flying was by a large contracted operator.)
Can it bring back retired pilots? Some might prefer shorter routes with fewer away from home nights, compared to their previous flying.
The article says domestic travel is at 80% of what it used to be. International travel is still down, which may account for some of what you experience. Foreign carriers probably aren’t operating their routes to and from the States like they used to.
I had to wait in line over 40 minutes to depart KMIA a couple months ago. Air traffic is busy again at some places and times. It just might not be the same as we’re used to.
The problem is that so many pilots were forced to retire early or left to other careers in 2020 that the airlines are struggling to fly an 80% schedule.
Poaching may be a strong word but that doesn’t make AvWeb irresponsible or clueless.
Many regionals have upgrade path agreements with the majors, so in a sense those major airlines do ‘own’ those pilots. If the major hires a lot of pilots from the regional years earlier than expected, that’s going to create a hardship for the regional to deal with…
Two years out of A&P school I asked the Air-Taxi operator for a raise. “You want a raise kid? Go get it”. The best advice I ever got.
Use any catch word you want, the only way the industry pay is going to get better is if the licensed personnel make it happen. GO GET IT! You jump-ship enough times and the air carriers will pay you. When people don’t talk with their feet the bosses laugh and cut your pay/benefits. Because they can.
Luck of the time and place, Matt. I get the babysitting 2,000 foot at a time climbs across umpteen sectors following the bunches of airplanes going the same way at the same time as I did before the crockdown.
There are no airplanes in storage at my airline.
ATC still is, and forever shall be by my 47 years experience, on its butt. They closed the gulf the other day but I refiled west out of Orlando and pushed the issue by taking deviations for WX to get my intended and desired route which was best and most efficient as well as clear of weather to Galveston and beyond… the gulf closure was not explained just what flow did that morning and left it all fricking day and never changed it once they left for home. 2 1/2 years to go to retirement and looking forward to it…
Yeah, I keep reading that a starting A&P is better-paid working at auto dealers. The exception might be if you specialize in avionics, which could be lucrative.
The real looming shortage is for A&P’s, not pilots, so I guess if you hang in there long enough, it will rain money.
