Originally published at: NTSB Warns of Sticking Exhaust Valves in Piston Aircraft Engines
The NTSB’s latest safety alert urges owners and mechanics to recognize warning signs before they lead to power loss
Remarkably the only things that haven’t doubled in price in the last few years are engine monitors. If you don’t have one, get one. It will pay for itself in easier and more accurate troubleshooting.
I have seen many exhaust valves that look much worse than that one. Guess what is the main cause of the carbon buildup. Not leaning properly and lead in the fuel. So better education and and how about getting the lead out???
I started using TCP , added to the fuel, which converts the lead-bromide to lead-phosphate, a soft material which goes out the exhaust.
It also will scavenge the existing lead from the exhaust valves.
I had another sticking exhaust valve and the TCP resolved the problem.
The biggest problem of sticking exhaust valves is leaded fuel.
Engines running on MOGAS don’t have this problem.
Just reamed the lead out of valve guides because of no compression on a cylinder.
Lead is not good for engines;
Stop the stonewalling over unleaded fuel!
My experience is that overheating cylinder heads are the first point of the chain of events. Leaded fuel has never been a factor, rather beneficial when it comes to lean running cylinders (for whatever reason). Overheating cylinders (mostly due to running too lean - not by lack of cooling air) mean the design clearances of the moving parts are not met anymore. Things are getting tight… Also, the exhaust valve is in a stream of hotter than expected gasses. Now the problems begin. Oil is coking, stem is gumming up in the guide, the valve lags and soon sticks. You feel it with rough running on a fixed pitch prop 4 cylinder engine. It just runs badly, and lacks power. On a six cylinder 300 hp monster, combined with a constant speed prop, you won’t feel any of this. Therefore an indication of EGT’s is a necessity for such engines. But a cool head saves stuck valves.
RUN LEAN OF PEAK, IDLE LEAN and avoid handling a highly neurotoxic chemical.
I’ve been doing it for 20 years, never a stuck valve, cylinder is absolutely clean as a whistle. Also pop cap every flight to vent and use camguard. 20 years of SR22 flying in two planes costs very little to do this and avoid problems.
