The National Transportation Safety Board (NTSB) released a safety recommendation report on Thursday calling for the FAA to require carbon monoxide (CO) detectors in general aviation aircraft. In addition, the report specifies that the agency should require CO detectors that comply “with an aviation-specific minimum performance standard with active aural or visual alerting.” The recommendation applies to all enclosed-cabin aircraft with reciprocating engines.
This is a companion discussion topic for the original entry at https://www.avweb.com/flight-safety/accidents-ntsb/ntsb-asks-faa-to-require-co-detectors-for-ga-aircraft
