Originally published at: Night, Rain, Piper Seneca
A landing gear warning during a rainy night training flight put a Piper Seneca crew’s decision-making and teamwork to the test.
A couple of questions about this event…
First, did anyone figure out how the crew was able to cycle the gear back up if the squat switch was in the “on the ground” position? Second, did you roll the emergency equipment for the eventual landing?
- The main issue was that the crew was unsure what exactly had caused the malfunction. After attempting to cycle the landing gear a couple of times without resolving the issue, they decided to use the emergency gear extension procedure.
- Good point! Unfortunately, the control tower was already closed, and the airport was operating in uncontrolled airspace. Nevertheless, the crew should have communicated the emergency situation over the UNICOM frequency to alert airport personnel and allow them to coordinate emergency services if needed. This is definitely an important lesson learned from the incident.
Thank you, Ron
