Honeywell's SmartRunway and SmartLanding products are upgrades to its Enhanced Ground Proximity Warning System, they talk, they're recently FAA-approved and they're designed to directly address major factors identified by the FAA that lead to runway incursions. SmartLanding is designed to identify things like which runway the pilot is approaching and whether the aircraft's airspeed is too high, or if the aircraft is flying too high or going to incur a long landing, and then conveys that information to the pilots through audio and visual signals. SmartRunway conveys advisories about a runway's length and its location, calling out and identifying each runway whenever the aircraft is approaching one either on the ground or in the air. For landing aircraft, it will call out distance remaining before and after landing. The products together address three key FAA-identified factors that lead to runway incursions: "communication, airport familiarization and cockpit procedures for maintaining orientation," according to Honeywell. The company says SmartRunway will be compatible with ADS-B functionality as that technology becomes available and should be available on certain new Boeing aircraft as they come off the line.
This is a companion discussion topic for the original entry at https://www.avweb.com/news/honeywell-software-addresses-situational-awareness-incursions
