Hartzell Propeller Inc. received a Supplemental Type Certificate (STC) from the Federal Aviation Administration for the company's new state-of-the-art lightweight Scimitar prop for all Cessna 172RG Cutlass aircraft.The newly designed and aggressively shaped Scimitar swept tip aluminum compact blended airfoil two-blade propeller and light-weight carbon fiber, all composite spinner assembly enhance standard-equipped propeller performance. More than 1,100 172RG aircraft have entered service.
This is a companion discussion topic for the original entry at https://www.avweb.com/press-releases/hartzell-receives-stc-for-cessna-172rg-cutlass
