Every student pilot (and no, I am not going to call you a “learner”) is familiar with the forced landing exercise. The airplane is out in the practice area and the instructor pulls the throttle to idle and tells you the engine just failed. You then frantically look around for a field to land in, quickly mumble the engine failure checks and concentrate on flying a gliding approach that will hopefully set you up for a landing on the field. The first few times you probably missed the field by a country mile but with a bit of practice you get better at flying an approach that would actually result in a survivable forced landing.
This is a companion discussion topic for the original entry at https://www.avweb.com/insider/guest-blog-the-wrong-way-to-teach-forced-landings
