Garmin Introduces Non-Certified ADS-B Solution
Garmin International Inc., a unit of Garmin Ltd. (NASDAQ: GRMN), today announced the GPS 20A, an ADS-B Out compliant WAAS GPS position source for experimental amateur-built (EAB) and light sport aircraft (LSA). For experimental aircraft owners that already have a Mode S Extended Squitter (ES) transponder such as the GTX 23ES, the non-certified GSP 20A provides aircraft owners with a simple, rule-compliant WAAS position source, which meets the TSO performance requirements set forth by the FAA.
This is a companion discussion topic for the original entry at https://www.avweb.com/press-releases/garmin-introduces-non-certified-ads-b-solution
