Garmin Adds IFR-Approved GPS/COMM - AVweb
Garmin has filled out its lineup of modern panel-mount, IFR-approved GPS units with the GNC 355, which combines an approach-capable GPS with a comm radio for $6995. Earlier this year, Garmin introduced a standalone IFR GPS and a version with a built-in Mode S transponder and ADS-B Out capabilities.
This is a companion discussion topic for the original entry at https://www.avweb.com/aviation-news/garmin-adds-ifr-approved-gps-com
But no USB charge port?
You want fries with that?
No, Raf … but I AM hearing that at SnF 2020, they’re coming out with a new paradigm shift in avionics … an all-in-one box containing GPS, Nav, comm, DG w/ HSI, horizon, diversity ADS-B transponder, intercom, 406 ELT, radar, Iridium sat phone, Wifi, Bluetooth, internal battery with sufficient excess energy to run six iPads, CO monitor, flight envelope protection, engine monitoring system and autopilot. Because it’ll be NORSEE approved, the introductory price will break the magic $100K barrier. For an extra $9,999, you can optionally order voice commands so you won’t even have to touch it. That model will also contain a quick detachable PLB. It’ll be called the GSAK 1001 … (swiss army knife). Weighing in at just under 3 pounds, all an installer will have to do is hook up power, antennas and pitot-static lines. I’m also hearing they’ll finally allow A&P installations, too. Wow ! Unfortunately, the STC’s to install it won’t be coming out until 2029 because … well … you know why.
I think I’m having Airventure withdrawal symptoms ? (AWS)
How is this product different from the GTN635?
It’s $4K less?
