Originally published at: FAA Tightens Line Up And Wait Requirements
Control towers must now dedicate a supervisory position to overseeing the procedure.
Truly mind boggling! As a UK controller for 38 years I simply do not understand how clearing aircraft to land on a runway which is in use by other aircraft is less dangerous than line up and wait.
UK controllers say that often and I really just don’t think you understand how busy we are. Come to my airport where you’re doing 100 operations an hour with closely spaced parallels - mixing IFR and VFR departures and arrivals - alongside half a dozen helicopters playing around, and you’ll quickly see that withholding landing clearance in lieu of anticipated separation is more dangerous and inefficient. The frequency congestion alone would be untenable.
For example: You would have me wait until aircraft 1 landing exits before clearing aircraft 2 who has been following with plenty of space. But, in that time I would be clearing him, I also need to issue exiting/hold short instructions to someone, clearing both parallels for takeoff, issue a traffic calls, extend another’s upwind, etc etc.
Go pull up an audio of a busy VFR tower and replay it with the radar, it quickly becomes apparent what I’m talking about. Cheers
Also, I hesitate to use LUAW during certain moments because it can be so congested that, at the moment I NEED to clear the aircraft for takeoff, I get a student pilot calling 10 out taking way too long on their initial call. Thank god I have the biggest voice on frequency and can talk over them when I need to ![]()
Given the disruptions in recent ATC events, LUAW is not currently advisable. In fact, ATC capacity restrictions should be implemented until system improvements can be verified. Absent that, cancellations and delays will continue to mount.
Surely this isn’t meant for small Class D towered airports? There might be 2 tower guys on shift on a good day. No supervisor hanging around to watch over things.
