An FAA assessment of SLSA manufacturers has found that "the majority" of manufacturers evaluated failed to prove compliance with the category's standards, and that could affect the certification status of some aircraft. The FAA announced its findings Thursday, stating that "aircraft within the existing fleets" of manufacturers not able to issue a valid Statement of Compliance "may no longer be eligible to retain their airworthiness certification as SLSA." Those aircraft may be eligible for ELSA certification, the FAA said. But the FAA also noted that a specific range of aircraft (not insignificant in number) may find even less favor from the current regulatory structure. The FAA "has determined that its original policy of reliance on manufacturers' Statements of Compliance" ... "should be reconsidered." Precisely how the FAA's notice will impact the existing fleet, and when, may require more clarification.
This is a companion discussion topic for the original entry at https://www.avweb.com/news/faa-slsa-certification-should-be-reconsidered
