EASA Issues Emergency Directive On A320 Aircraft
Originally published at: EASA Issues Emergency Directive On A320 Aircraft
Investigators identified a critical hardware vulnerability following an in-flight incident.
Usually when a cause is identified there is hard factual evidence. Like the 737-Max problems that were the MCAS system. Saying “solar radiation” is pretty weak, I would like to see how they proved it. In an aircraft known to be “fly-by-wire”, there are many microcontrollers with embedded logic. That means tiny computers placed all over the plane. Unless they rad-harden the plane this same “solar radiation” data corruption can occur again and again. Maybe this is just a pacifying “finding” so people think there is little to worry about for Airbus?If the cause is unknown, the fleet would be grounded, just like the Max.
I agree that a lot of this just don’t pass the smell test. First, as is usually the case, the Airbus solution is a quick software update. In this case the fix is actually replacing a previous update with a prior version. Some older airframes actually need hardware updates. That doesn’t sound like a software issue to me. Nobody wants to know how the flawed update made it into the aircraft? It is said a “line of code” was missing that “protects” the system from radiation. It would be very interesting to see how that is works. After the MAX issues, we were led to believe by the FAA and EASA that all software updates needed to be validated by a second independent source. If so, how did that missing line of code escape them also. And just who are they?
What this really says and nobody wants to say out loud, is that the FAA and EASA really has little capability to keep us as safe as they would like us to believe. It might also say that Airbus learned a lot after the Max issue as to how best bury an issue. How many more gremlins are hiding in all of those computers with the millions of lines of code that make it all work? How can we be assured that any simple future update won’t induce even more dangerous bugs? Or, what was in the flawed update that apparently wasn’t all that important in the first place? Must be something the previous version didn’t have. Or, dummer yet, when the sun decides to throw us another “solar radiation” burst.
I think a lot of people are really gullible here. I just watched a TV reporter ask “an airline expert” some of these questions. The answer? We should be so thankful for the smart engineers that discovered this so quickly". Well, it wouldn’t have been quick enough if that Jet Blue decided to take a quick 500 foot dive during a 400 foot approach.
I used to work for Boeing Satellite Systems. We made satellites and radiation hardening is real. But it was pervasive, not a point solution. It had to be. I cannot believe that “smart engineers” are basically saying their guess is good. Boeing proved that the MCAS would fail when sensor input was unavailable and they included a hardware change to always have at least 2 sensors in case one is not providing input. I used to be a professional software engineer, Fringe and error cases are the major parts of any good software. I think an airline expert is the wrong person for the assessment of coding issues.
It’s just like the new cars they’re making nowadays, filled with too many computers and modules that nobody can fix anything without expensive readers. It is making it hard for most mechanics to deal with. This computer age is going to kill people especially when AI comes in.
Who led you to believe that? Who is that second independent source and what exactly are they providing?
No, Boeing didn’t prove anything of the sort. When AOA sensor data is unavailable or invalid the ADIRU sends a “No data computed” for airspeed and altitude and those parameters are blanked on the displays.
The hardware change to utilize two AOA sensors didn’t provide redundancy if one is not working. A discrepancy between the two does not allow a determination as to which one is erroneous. Thus the scheme provides integrity monitoring; a discrepancy indicates AOA sensing is unreliable and neither value is used.
True parametric redundancy would require three or more sources and a source-select mechanism that compares the source outputs, determines whether the number of outputs that mutually match meets or exceeds the minimum functional assurance criterion (2/3, 5/7, 5/9, 7/9, etc.) and then selects one of them to be the source for the consuming system(s). If the minimum functional assurance is not met the source-select has to send a “parameter not computed” or equivalent message instead.
LOL. A lot of people were similarly gullible when two 737 MAX jets crashed six years ago. The cause—determined by authors of aviation blogs and the news media long before the official investigations were completed—was variously published as a monstrous force that pushed the nose down unrelentingly, driven by badly-written, corner-cutting computer code that the pilots could not override or had no time to react to or didn’t know how to for lack of training on a new system called MCAS that Boeing kept hidden to save money on training.
The gullible public swallowed it all—hook, line and sinker—failing to consider that the MCAS, when operating normally, worked in the background to de-trim the stabilizer to provide the linearly increasing resistance a human pilot expects as the yoke is pulled further and further aft. As such, a pilot can’t detect its normal operation; indeed there is no human interface by which a pilot can uniquely detect or control its operation—not even an on/off switch. The trim wheel does spin when MCAS operates, but there are other systems that indistinguishably also spin that wheel. Since they can’t detect, monitor, adjust or operate MCAS, there is no reason to tell pilots about it. With no human interface, training is in fact impossible.
When MCAS operated unnecessarily, the result was a rapidly increasing nose down pitch that is certainly detectable. During basic 737 type rating training and periodic training thereafter, pilots learn to associate a rapid and increasing uncommanded pitch deviation (up or down) with a spinning trim wheel to diagnose a Runaway Stabilizer Trim condition. The simple procedure for handling a runaway trim is memorized to save time when it does occur and essentially consists of turning off the trim system and thereafter flying using the trim wheel to manually trim.
The flight and voice data recorded gave no indication that the three crew sets who encountered a runaway stab trim had even heard of the condition, let alone received training on it. One crew set did receive just-in-time training from a deadheading pilot of a different airline who happened to be on the flight deck; they executed the runaway procedure and landed safely at their destination. The other two crashed.
Numerous faults can occur within the systems that control the stabilizer position to cause a runaway trim, but pilots are not trained to know them or to troubleshoot to identify them when a runaway does occur because such discrimination is not possible in flight and there is only one procedural remedy regardless of the cause, be it a stuck relay, MCAS, shorted wiring or a failed trim switch on the yoke that the pilots use.
The gullible public doesn’t know all this so they simply absorbed the techno-nonsense that was published, mostly by pilots who thought pilot training, which teaches a pilot how to operate an airplane, also teaches them how to design airplanes or to critique an airplane’s design in the aftermath of a crash and determine the cause. They—and the people who thought pilots are competent to decide the cause of crashes—seemed to not recognize that a pilot is to an airplane as a taxicab driver is to a taxicab and they demanded training on a system that didn’t need any. Moreover, they began to theorize as to the cause before much of the data was available and had never heard or failed to heed Sherlock Holmes’ wise advice: “It is a capital mistake to theorize before one has data. Insensibly [subconsciously] one begins to twist facts to suit theories, instead of theories to suit facts.”
Thanks to those pretending competence in aero engineering, helped by those who unethically published the false but plausible analysis without verification and those who believed them and unnecessarily grounded the fleet, the real reason for the crashes—inadequacy of training at two airlines—went unnoticed.
It was considered unacceptably racist and politically improper to even suggest that the training of pilots in two developing countries was deficient, so the FAA while desperately looking—after the fact—for other reasons to ground the 737 MAX came up with “cosmic rays” potentially corrupting precisely the memory locations holding the variables [flaps_retracted] and [autopilot_engaged] such that their logic would be inverted to erroneously activate MCAS.
The gullible public has come to accept the widely published but false reasons for the crashes and believes that flight safety was improved by the 737 MAX grounding and purported fixes.
