As we reported earlier, the Boeing 737 MAX has been approved to return to service in the U.S. after modifications and pilot flight training have been completed. The European Union Aviation Safety Agency (EASA) previously reported that the MAX is likely to be released for service in January and today published a Proposed Airworthiness Directive (PAD) “signaling its intention to approve the aircraft to return to Europe’s skies within a matter of weeks.” Critically, the agency says that “EASA, and regulators in Canada and Brazil, worked closely with the FAA and Boeing throughout the last 20 months to return the plane safely to operations. The EASA Proposed Airworthiness Directive requires the same changes to the aircraft as the FAA, meaning that there will be no software or technical differences between the aircraft operated by the United States operators and by the EASA member states operators …” These include, of course, updates to the Boeing’s software that alter MCAS function, as well as defining new training for pilots and a physical modification to address wire chafing in the stabilizer-control circuit.
Too much automation and too much information on giant LED MFDs allow people who don’t understand flying to seemingly safely fly. They also allow Pilots to loose their skills since the toys are so helpful. When the automation fails and then MFDs go blank you will still need a pilot who knows attitude flying and needle, ball and airspeed skills. Flying training needs to make sure that all pilots understand their airplane. AQP is a good start.
Your poll. “Would You Fly a 737 MAX Now?”
Results say 9% of 161 airline pilots yes!!
Can’t believe how the others could be negative.
What do they know that can be so discouraging?
Still have the cut out switches I presume.
But those things occur in a vanishingly small percentage of flights. It wasn’t that long ago that losing two or three airliners a year in the US was normal. The reason there are fewer is automation.
But that’s why we have pilots - in case there is a problem. Because those 200 passengers per trip expect to arrive safely, and can’t fathom anything else.
The families of the MH370 accident camped out at the airport for a year waiting for their loved ones to return - the idea that a planeload of passengers could just disappear was not something they expected or could process. It’s our job as aviation professionals to prevent that from happening.
Although the US is averaging 0 accidents per year now, that doesn’t mean it won’t be more in a future year if we get complacent.
I’m still very troubled that the 737 MAX software was outsourced to $15/hour programmers, and that Boeing submitted false documents to the FAA.
Software is not a black box with a connector that isolates the device from the overall aircraft. Software outputs don’t obey the laws of physics - how it’s written and tested matters.
Whether false documnents are submitted to the FAA knowingly or unknowingly, that shouldn’t happen, especially with aerospace products that are life-critical for hundreds of people per trip.
For those unfamiliar with how aerospace is regulated, the FAA relies primarily on documentation submitted by mfgs. The FAA doesn’t lurk in factories 24x7 with flashlights inspecting each part.
