Devotion: Made Like They Used to Make Them - AVweb
If there’s a single word to describe the recently released film Devotion, it would be restrained. Or perhaps understated. The writers and director resisted the urge to tart up the production with the over-the-top CGI pyrotechnics that I thought ruined Red Tails and although racial strife has a role in the story, the director admirably resisted making it the star. The viewer will get the point without being hammered senseless by repeated displays of racial injustice. In that sense, and given that director JD Dillard is himself black, it’s possible that this film represents a departure in how Hollywood, or at least one small segment of it, depicts the complicated history of race in these United States. Or maybe I should exercise restraint myself and just call it a good flying movie. It certainly is that.
This is a companion discussion topic for the original entry at https://www.avweb.com/insider/devotion-made-like-they-used-to-make-them
Scattering ashes over Long Island Sound reminds me of a story. When we picked up my father’s ashes, the funeral director warned that if we were going to scatter his ashes from a boat into Long Island Sound, to make sure to open the box and empty it completely.
We hadn’t planned on doing so, but I was curious as to why - was there a legal or moral reason behind the warning?
He said no, it’s just that when people get out on the boat, and it’s windy, they get worried about ashes swirling about and getting on the boat and mourners. So sometimes they decide to let the sealed box slide overboard as a solemn way to commit it to the depths.
Now, the box seems pretty heavy, and sinks straightaway. But it’s actually close to being neutrally buoyant. And the Sound has lots of tides and currents, and the box tends to tumble along the sear floor. After several years, it sometimes washes up on shore.
The part most people don’t realize is that, before a person is cremated, a metal coin with a coded serial number is attached to the body. This coin goes through the whole cremation process and ends up in the ashes, inside the box, ensuring the correct cremains go to the correct loved ones. So when the box shows up and is found, eventually the police find the coin and contact the appropriate funeral home.
And they have the unfortunate task of calling the family and telling them, “Your dad just showed up.”
A firecracker in a paper sack works well. Just be certain that you have a reliable fuse.
Scattering cremains make for hilariously funny moments. Dude did not want to leave the cabin. I’m not doing that anymore.
“The dust-to-dust dogma being a durable belief…” It isn’t just a belief, it’s an actual, physical fact. However I still enjoyed the piece, Paul. So do you have any thoughts or plans for your final disposition and will it involve a vacuum cleaner hose? As for me, I’d be happy if my family scatters my remains somewhere on a high place with a breathtaking view and perhaps an airplane flying by once in a while.
I offered to scatter my roommate’s dad’s ashes out of a friend’s Cub down the grass runway of a nearby airport. (He was a long-time grass strip and Cub aficionado, though when ht bought an airplane, it was a 150.) I rigged up a piece of PVC with a big funnel and a 45 degree elbow on the end, and held it out the side door with the elbow in the slip stream, below the level of the tailfeathers. Worked well enough, though it took several passes to get all of the ashes out. If there is a next time, I’ll use larger pipe.
I strongly recommend practicing with some fine grained kitty litter first. (Don’t ask why I know this).
In the end I use the paper bag method. Brown paper bag with a line taped securely to the side. Line secured in cockpit, dump bag out window, it comes up short - ripping the bag open. Line length to prevent interference with tailfeathers.
Add flour to mix if the relatives want to see a white “puff”. Otherwise cremains are a bit neutral toned and don’t show up well.
If scattering over water (especially Long Island Sound!) be aware of International Convention for the Prevention of Pollution From Ships, 1973, commonly known as Annex V of MARPOL (Marine Pollution) 73/78. Not sure it applies to aircraft as such. But cremains are of a size that by the convention they should be scattered 3+ miles offshore…
Back in the 1980s a local lawyer friend of mine had a sideline called Aerial Burials that I did a few flights for.
After the usual initial disaster he came up with a piece of 3 inch PVC drain pipe with a hinged door with a latch on one end and a 3 x 1 1/2 inch reducer on the other that was removable. It had a couple of simple clamps that would attach it to the wing strut of whatever rental Cessna we were using and a string from the latch ran into the pilot side window. You’d just make sure the latch was closed, remove the reducer from the other end, pour in the ashes, replace the reducer and put a piece of duct tape over the small end, which was removed before takeoff. You’d get over whatever lake or golf course, open the window and pull the string to open the door and the airstream pressure would disburse the ashes.
He had a little trouble from the FAA after one his first drops over a golf course. One of the neighbors saw him go over and picked some larger bone parts off the hood of his Cadillac and went off to see the FAA with a baggy. After that he had the crematorium grind the ashes twice. The FAA maintained that he needed a commercial license and a 135 certificate and he maintained that it was more like crop dusting. He offered to call them the next time he did a drop and have them violate him. They never took him up on the offer.
Same principle applies to ping pong balls. No disrespect intended. In a small NE Texas town in the late 60s, I, and my CFI, distributed those ping pong balls, with a few stamped with business names, along Main St. for the local Chamber of Commerce. The aircraft was a C-150. When the a/c window was opened and the carefully made hatch slid forward the balls made a really cool clatter, but few dropped. On the second pass, IIRC, I pulled the whole bottom of the box open with great success. The string of balls whirled in the slipstream a moment then all fell to the street.
Yes, we got a waiver from the FAA to fly at 500 feet!
Almost forgot, The pilot was a pre-med student and I Journalism. We knew nothing of the aforesaid principle of carburation despite our, we thought, vast knowledge of everything.
I used to work for a Beechcraft dealer in NY. One time an owner came in and asked to use our shop vac to clean out his plane after a ash drop failure of his friend Irving. From that day on, the vacuum was called Irving.
GREAT idea … we could dump the ashes AND enjoy a flour bombing contest simultaneously.
I HAD to say that :slight_smile:
If BB King can have a guitar named Lucille, a vacuum cleaner named Irving isn’t too far a stretch. And – oh by the way – I take my vehicles to a facility across the street from a crematorium. They guys there say they can always tell when they’re “burning one.” Ash settles on the cars. NOT for me.
Hello Paul,
This is Mark Pederson from Homeward Bound Aerial Services (Ashscattering.org). My wife and I loved your blog. We would very much like to continue this dialog and have many wonderful stories on the subject.
Well done!
Mark & Jane Pederson
Dumping ashes out the window like a used cigarette?
Somewhere an Indian on the side of the road is weeping.
Somewhere an Indian on the side of the road is weeping.’
Sadly, emotional attachment and superstitions still rule the societal day, giving a false sense of freedom and chutzpah to make something entirely personal into a public use/abuse event.
True freedom demonstrates a much broader sense of personal responsibility.
When one of the members of our skydiving community passed away, some of us built a contraption out of ABS pipe and fittings - complete with gate valves - and fastened it to the strut of a plane. It worked a treat for spreading his ashes. (I was flying the photo plane in formation.)
The trick - whatever you’re dropping - is to get it well outside the aircraft before letting it go. One of the jumpers I flew with a smoke generator attached to his leg didn’t get his leg far enough out the door before setting it off, and the entire cabin filled up with smoke - which fortunately dissipated quickly once he left.
Recalling a less-than-ideal experience air droppin my brother’s ashes over the airport that he’d fondly referred to as Littleton International in Colorado in 1977, I designed and built a device specifically for the task, when it came time to scattering my dad’s ashes over Land Between the Lakes, Kentucky in 1995. I saved the device in a box in my attic. I was in a bit of a haze at the time, having just lost my dad, and so as I read this article, I realized that I couldn’t remember exactly how the device worked, or even that much about what it looked like, but I did remember that it worked perfectly. So I’ve just made a trip to my attic and found the box containing the device and it’s triggered a lot of memories, some sad, some happy, and a bit of pride. At the risk of sounding immodest, I’m duly impressed that I was able to design and build this thing as well as I did. Dad would have been proud. If there were a market for it, I’d try to patent it. It’s a bit over 4ft long. The top section (ash chamber) is about 16in long and made of 3.5in pvc. It transitions to 2.5in pvc for about 27in of ejector tube. The top of the ash chamber has a domed pvc cap (unsecured for filling) with an approx. 5/8in hole drilled in the center through which a long, not quite snug fit 1/2in pvc tube runs all the way to the bottom of the ejector tube, where it passes through and is secured to another smaller domed cap which fits a little more snuggly (domed side in) INSIDE the end of the 2.5in pvc pipe. The 1/2in pvc and smaller domed cap act as a plunger. The plan was to remove the large dome, fill the ash chamber and cap it before take off. I had drilled a hole through the 1/2in pvc at the top (exterior) of the ash chamber’s dome and pinned it with a finishing nail (rather inelegant) to keep the plunger from accidentally opening prematurely. When I reached the drop zone, I extended the ejector tube out the window and removed the safety pin. I pushed the plunger to open the ejector end and the ashes were sucked out the end and away from the plane. Bon voyage, Pops!
Paul: Thank you for re-telling the story and for the film review. Like you, I hope it does well at the box office and my son (14 years old and fascinated with US military history) and I look forward to seeing it ourselves. Do you have any sort of an update on your airplane and hangar (and the airport in general) at Venice?
Paul, your essays are priceless and always worth reading more than once. You are a craftsman with words and your humanity is evident from your insights. Thank you.
