Bonanza's Engine Out Off-Field Crash Landing (With Video)
Last month, nearly 8,000-hour ATP certificated pilot Dale Hemman posted to YouTube multiple views of his 2012 engine-out controlled crash in a Bonanza at Fairbanks, Alaska and, Wednesday, the NTSB released its probable cause report, but questions remain. On the morning of July 26, 2012, Hemman was leading a flight of 12 aircraft on an aerial tour for a group called "Let's Fly Alaska." He was flying with one other occupant. Neither was significantly injured in the crash. His aircraft, a 1975 Beechcraft F33A Bonanza modified by D'Shannon Products with a 300-hp Continental IO-550, carried four video cameras -- all externally mounted. Each camera recorded a different angle of the events that transpired approximately 41 seconds after the plane began its takeoff roll. They show that while climbing at 400 feet AGL on departure with the gear up, the aircraft lost power. Hemman was faced with several options that included trees and an open field that sat just across a channel of water. It was, possibly, at the optimistic end of the aircraft's glide range. After an initial roll away from it, Hemman chose the field. It was roughly 90 degrees off his right wing.
This is a companion discussion topic for the original entry at https://www.avweb.com/news/pilot-wants-others-to-learn-from-crash-video
