Avfuel Holds Sustainable Fuel Demo - AVweb
Aviation fuel and services provider Avfuel is holding a sustainable aviation fuel (SAF) demonstration at Wyoming’s Jackson Hole Airport (JAC) on Tuesday and Wednesday. During the event, the company says it will supply 7,300 gallons of SAF to the Jackson Hole Aviation FBO for use by “operators flying in and out of the airfield during the demonstration days.” The demonstration is being conducted alongside the ribbon-cutting ceremony for the airport’s new underground stormwater detention and filtration system.
This is a companion discussion topic for the original entry at https://www.avweb.com/ownership/fuel-news/avfuel-holds-sustainable-fuel-demo
Feckless virtue signaling.
Gevo’s major product is isobutanol fermented from starches. To make an acceptable jet fuel additive they’d need to go through several oil-refining-like chemical manipulations.
I think their original business plan was to capitalize on the availability of idled ethanol plants to produce isobutanol instead, as an alternative oxygenate for mogas. It is difficult to see how this will be cost competitive with classic path to jet fuel - refining of petroleum distillate. The environmental benefit may be modest when the agricultural and chemical processing impacts are factored in.
Ironically, less expensive isobutanol might be an attractive additive to ASTM unleaded avgas in view of its RVP and water rejection properties.
We’ll now be able to burn lots of fuel and not worrying about running out.
This is a “benefit to our environment”?
You lost me…
