Angle of Attack (AoA) Technology Comparison
Feature Vane-Based System Pressure-Ratio Based System
Primary Method Mechanical Alignment Pressure Ratio
Complexity High (Mechanical components such as bearings and seals) Low (No moving parts)
Installation Requires a precision-cut hole in the aircraft’s skin and complex internal electronics Can be bolted on or integrated into an existing plate, making it a much simpler retrofit for GA aircraft.
Accuracy Accurate across all flight regimes. Accurate across all flight regimes, except during significant slips/skids.
Maintenance Requires thorough inspection for sticking, wear, and damage before every flight. Low maintenance; primarily requires keeping the ports clear of debris.
Failure Modes Mechanical jamming, bird strikes, icing, snow, or heavy rain; often fails without warning. Blocked ports (ice/bugs) or water in lines, but includes built-in diagnostic warnings.
Weight/Size Larger, heavier, and creates more aerodynamic drag. Smaller, lighter, and creates lower drag.
Target Aircraft Preferred for commercial airliners and fighter jets due to high sensitivity; typically 2 to 4 redundant units per aircraft. Widely popular in General Aviation because they are lighter, cost-effective, and easier to install.
Summary
If you are flying a high-performance jet where precision at Mach speeds is critical, a redundant vane-based system is the industry standard. However, for those flying light piston or turboprop aircraft who want a reliable, low-maintenance safety tool to prevent stalls and loss-of-control accidents, a pressure-ratio system is usually the more practical and cost-effective choice.
Advanced pressure-ratio systems have the ability to sense blocked ports and produce appropriate cockpit warnings. Historically, fatal accidents resulting from relying on false indications from damaged vane-based systems have even forced some manufacturers of those systems out of business.
