Alternative-energy aircraft developer Ampaire has signed a memorandum of understanding (MOU) with Tamarack Aerospace Group “to develop further aerodynamic upgrades for Ampaire’s family of hybrid electric aircraft.” Plans call for Tamarack to adapt its “Smartwing” active winglet technology to Ampaire’s alternative energy variants of the Cessna 208 Caravan, Twin Otter and Beechcraft King Air aircraft. Tamarack active winglet systems are now installed on more than 170 Cessna CitationJets, with climb-gradient and fuel-consumption/range improvements of up to 10 percent, according to Tamarack. The technology also “smooths flight, and improves the ability to take off and land on shorter runways regardless of high/hot conditions and payload,” said Tamarack.
“Operational Necessity” is a term used in USN NATOPS. Whenever it was suggested as justification for a flight, the next assignment was to actually look it up in NATOPS…defined there as circumstances that may result in the loss of the aircraft and/or crew. Similarly, it is the PIC’s responsibility to prevent the forging of a PBF flight mishap chain…if they can’t (or won’t) they shouldn’t be the PIC of any flight. Most have heard the “Can Do” line “it’s better to die than to look bad” but the often unspoken next line is…“but you can do both”.
From an engineering standpoint simple is lighter than complex…if induced drag is the target, complexity (weight) is the enemy…if parasitic (form) drag is the target, then complexity is the tradeoff for retractable gear/flaps. Putting active wingtips on a bolted gear plane implies lipstick on a pig.
For all the folks who feel the need to label this view “luddite”, pardon my skepticism, but after a few decades of wading through “visionary engineering” proposals, my patience is worn by those who ignore physics, the encountered environment and embrace needless complexity without thought to the entire system (read maint) lifecycle.
I’ll give tech demonstrations a pass, but the rush to widely field unproven concepts is going to bite the industry when something easily forecast takes out a planeload of pax.
My guess is because wheel pants/fairings aren’t great for unimproved/grass strips, which is what the Caravan is good at. Same reason why retractable gear wouldn’t be desirable. At least the winglets are up high on the wings, so less susceptible to damage from gravel/etc.
