American Flight Uses Non-Biobased SAF in U.S. First
Originally published at: American Flight Uses Non-Biobased SAF in U.S. First
Infinium produced the fuel using waste carbon dioxide and renewable electricity.
Story is misleading. What is waste carbon dioxide? And how much of the CO2 derivative was blended with conventional jet fuel? Was the ratio 90 - 10 jet fuel to whatever it is? Clickbait
I agree. What is the ratio? What is the source of the CO2? Also, what is the real cost? Given enough energy, you can make about anything.
Just curious, does using SAF require a STC for that aircraft and if not would anyone know why? None of the turbine powered airplanes I have flown have SAF listed in the POH as approved jet fuel.
According to AI overview;
E-SAF (e-aviation synthetic fuel or power-to-liquid SAF) is significantly more expensive than traditional fossil jet fuel. While conventional fossil jet fuel typically trades around $2 to $2.50 per gallon (roughly $600 to $734 per tonne), e-SAF production costs range anywhere from $7 to $16+ per gallon (or roughly €7,695 / ~$7,500+ per tonne). This makes e-SAF roughly 4 to 13 times more expensive than conventional fossil fuels depending on regional pricing and calculation metrics.
