Akoya Lands At Oshkosh
Can't decide whether you want to land your LSA on runways, lakes or snow-covered fields? LISA Airplanes arrived at Oshkosh with a flying prototype that can do all three. The Akoya's fuselage/hull is unique in that in the place of a traditional stepped seaplane hull it has two water seafoils -- stubby fins jutting down from the hull -- that lift the aircraft out of the water. The company claims they also produce almost no drag in the air, which allows for impressive fuel efficiency. The Akoya's other performance numbers best another well-known LSA amphibian.
This is a companion discussion topic for the original entry at https://www.avweb.com/air-shows-events/akoya-lands-at-oshkosh
