New flight recorder data says Air Canada flight 759 (ACA759), an Airbus A320, descended as low as 59 feet above ground level and the 55-foot tall 787 on Taxiway C before beginning to climb out on its go-around—coming potentially as close as four feet from a collision. At four minutes to midnight on July 7, ACA759, which had been cleared to land on Runway 28R at San Francisco International, instead lined up on Taxiway C, on which three aircraft were holding for takeoff. After prompting by one of the pilots of United Flight 1 (UA1), the first in line for takeoff on Taxiway C, who was well positioned to see that ACA759 was not headed toward a runway, the tower controller instructed ACA759 to go around. After advancing the thrust levers at 85 feet above ground level, the aircraft continued to sink to a minimum altitude of 59 feet, before overflying at least two more aircraft. Altitude figures in the NTSB report are likely based on the A320's radar altimeter, according to an A320 pilot who spoke with AVweb about the incident. The extent to which the accuracy of the radar altimeter may have been influenced by extremely close proximity to aircraft underneath has not yet been reported by the NTSB.
This is a companion discussion topic for the original entry at https://www.avweb.com/news/air-canada-flight-misses-by-four-feet
