Paul, thanks again for what you do to promote aviation safety. I think you just saved a life or two with that video. Someone will see that video and have an engine failure on takeoff that will benefit from going through your teachings. 16 years ago, I lost oil pressure in my Bonanza (ended up being due to a piston pin cap failure and subsequent effect on the engine driven fuel pump) followed by a thrown rod 1 minute later. I was 7 miles from an airport and 3500 AGL. I had just read an article in the ABS magazine about gear up landings and how they are a non-event in the Bonanza, and also what you said about the airplane being expendable and insured, and the goal not being to save the aircraft, but the passengers. I had time to prepare for the engine failure I knew was coming in a minute with loss of oil pressure. I also did not have to immediately push the nose over as I was in cruise. Immediately pitching down to the approximate best glide attitude from the initial climb attitude is so critical. Without practice, every instinct is to pull back to keep the ground away. Practicing repeatedly until that instinct is extinguished is life-saving.
This is a companion discussion topic for the original entry at https://www.avweb.com/features/reader-mail/top-letters-and-comments-july-3-2020
