This will be a short chapter because, unfortunately, I did not make full notes on the lesson. No doubt I was excited and over-exuberant, and possibly incoherent, after this flight. I jotted down only a couple of sentences, and am therefore a bit blank as to the finer points. It will not be difficult to reconstruct the situation, however; I am good at that sort of thing.What things I do not remember I will construct from my own fertile imagination; if they happen not to fit some preconceived notion you may have, that is not my fault. You shouldn't allow yourself preconceptions (check the 'Human Factors' section in the manual).
This is a companion discussion topic for the original entry at https://www.avweb.com/flight-safety/the-cessna-the-sky-and-the-cartoonist-chapters-two-and-three
