Henderson, NV: Robotic Skies has completed the first field installation of a Garmin GDL 84 Automatic Dependent Surveillance-Broadcast (ADS-B) datalink solution into an unmanned platform. Garmin dealer Kings Avionics, Inc., of Henderson, Nevada, a full service Part 145 repair facility and Robotic Skies' founding partner, performed the installation. The GDL 84 was installed into an Unmanned Systems Incorporated (USI) SandstormTM aircraft that is currently engaged in airspace integration testing in Nevada, and operates under an Experimental Type Certificate.
This is a companion discussion topic for the original entry at https://www.avweb.com/press-releases/robotic-skies-completes-first-field-installation-of-gdl84-ads-b-into-uas
