Report: Gulfstream Hits 'Metallic' Object at 27,000 Feet
That aircraft climbs very quick. Also that is the altitude that the jetstream usually operates. The speed increase was ground speed. Not uncommon when you suddenly pick up 70+ knots on the tail. The plane actually slowed 50 knots of airspeed. Quite common as power is lost. Turbine engines are much tougher than most think. They have even continued to run after ingesting people.
