Pilot Error May Have Contributed To Endeavor Air CRJ-900 Crash
Thankyou.
I take the difference as sensitivity.
Pilot should know how much to change pitch and risk of making sink rate high.
Still a conventional wing (not a delta).
(Early in Boeing 737 operations one overran runway in India, because former DC-6 pilot rotated too much so airplane took a long time to touch down.
Pacific Western initially ensured firm touchdown, then developed/taught a smoother arrival as some pax got nervous, B737-200 with F40 doesn’t need much flare.
It wasn’t the pilot’s fault. It was the asphalt…
Amount of flair needed depends to at least some degree on height of wing above landing surface.
I have to read course material on that, drag may change as well.
CRJ and B737 are low to surface.
(As are DC-9 and derivatives.
Wings also vary in leading edge flaps/slats, DC9-10 did not have any which contributed to an over-run, I forget details.)
I never get tired of saying I told you so.
Yep. And if the aircraft wasn’t in a steady bank to the right, but was still rolling that would create some amount of additional force on the right landing gear and then the wing.
Questions include:
  • was PM not noticing sink rate increasing? CVR was recovered, was it readable?
  • was there another change of wind at the last moment, of direction (think swirling wind). I wonder if there would be a difference between left and right pitot-static systems which I expect fed different sets of instruments.
Some considerations:
Under normal circumstances the FO should have been proficient in the airplane at 400 plus hours. The unknown factors are:
How much hands on flying had she done.
Were most of the Captains she had flown with good instructors/mentors or were they not very proficient in the airplane.
Some facts about wing loading:
CRJ 900 Gross weight 80,500
wing loading 50# sq ft
DC9-30 GW 108,000#
wing loading 108,000 # sq ft
King Air 200 wing loading 41.3 # sq ft
P 51 wing loading 41.2 # sq ft
Beech Baron 58 27.6
CJ One 22.3
With good instruction/mentoring an average pilot can transition from a cabin class piston twin to a DC9 and be reasonably proficient in 100 hours. By reasonably proficient I mean capable of making a minimums approach and landing safely should the Capt become incapasitated
Correct DC9 wing loading to 108# sq ft. Some 30 series are considerably higher.
114,000 # Gross Weight on same wing as earlier 30 series.
