Originally published at: 'It Worked Last Time'
A fatal Cessna 210 accident shows how repeated success can erode safety margins.
Doing spins in an airplane not approved for spins is not the same as exceeding a demonstrated crosswind number. Spins in unapproved planes is going against a limitation. Demonstrated crosswind numbers in normal category and some transport category planes is not a limitation. Not any different than the “avoid slips with full flaps” advisory in a C172. Doing something that exceeds or goes against a limitation, besides being illegal, is just stupid!
Cessna 210 is a TRANSPORT airplane. No reason in normal operation to get anywhere near spinning one. About as sensible as spinning a Boeing 747.
If you want students to understand spins for heaven’s sakes do it in a Pitts, Citabria, CT4 etc. which is designed to do them.
I use a Redbird MCX AATD simulator to teach stalls and spins to pre-students before they ever go to the aircraft. We have a 10 hour sim course that teaches all PPL maneuvers, traffic pattern, comms, rejected takeoffs, aborted takeoffs, emergency landings into fields, normal landings etc. When students subsequently see the maneuvers in the aircraft it is second nature. When students solo an aircraft, after having completed the sim course, they are better prepared for flight including spins and recovery from spins.
There were three people in the Cessna 210. That changes the center of mass a LOT compared with two people. The article doesn’t say whether the instructor’s previous spins in the 210 were with only two people. Note that other four-seat airplanes approved for intentional spins, like the Cherokee 140, allow only two people in the airplane when spinning. Back in ground school, I learned about unrecoverable flat spins resulting from rearward center of mass, and I decided I didn’t want to experience one.
Darwin award winner…
The weight and seat position of the PAX is very relevant to the spiin recovery and possibly aircraft structural margins of safety.
ATSB Report… https://www.atsb.gov.au/sites/default/files/documents/2026-10/AO-2026-010%20Final.pdf
