In a notice that is scheduled to be published in the Federal Register on Jan. 18, the agency says there are some safeguards that must be in place before it can approve the mods. The system must be able to be disabled when the aircraft is on the ground and in maintenance. It also has to be designed so it doesn’t damage the airplane or really anything other than the incoming missile. The system will also have to be placarded and fully documented for operation and maintenance. If it approves FedEx’s application, it will only apply to the A321-200 and modification of other types will require going through the whole process.
This is a companion discussion topic for the original entry at https://www.avweb.com/aviation-news/fedex-wants-anti-missile-lasers-for-aircraft
