FAA Grounds Blue Origin After Launch Crash - AVweb
It’s different in this case, because it involves spaceflight, which never will be as safe or reliable as commercial air transportation. At least, not with the existing technology.
This is actually closer to the FAA grounding all Cirrus aircraft because of a CAPS deployment due to a failed engine.
Now if the escape system didn’t work, that would be a different matter.
