94 octane fuel, mogas or unleaded 100LL base, it does not matter.
Ethanol has NO business in any internal combustion engine fuel period. ETOH is an after refinery blend and is not present in automotive fuels unless mandated by certain states for on road use.
Currently, there are only six states that DO have a mandatory ethanol law like this: Florida, Hawaii, Minnesota, Missouri, Oregon, and Washington state.
In Minnesota ethanol is exempt from the gas used in aircraft, watercraft, motorsport racing, collector vehicles and off-road use, motorcycles, 2 cycle, and small engines, and snowmobiles. It requires 91 octane fuel or above.
Missouri follows Minnesota, but exempts gas sold at airports and marinas.
Florida is even better, in that it does not require any octane restriction on nonblended gas.
Oregon originally mandated blending for everything and changed its mind in 2008, to follow pretty much Minnesota, but then OR didnât let you pump your own gas until recently.
That leaves just Washington and Hawaii. Washington exempts airport gas, and I donât know about HI.
Michigan makes it harder to find, but itâs there and the gas stations before Granholm, the ex-governor and ex-Sec Energy mandated removal of pump labeling as to fuel composition to hide the Ethanol.
So, the only problem we have is how to get it to the airport. Until we solve this problem, I transport it in a DOT approved permanently installed tank in a truck with a pump, and have pumped over 10000 gallons into my airplane over the years after the local field discontinued Mogas. About 2/3 of the GA fleet can and does use mogas.
