Reid-Hillview served as a receiver airport when GA was virtually kicked off of SJC. Problem is it is square miles of land in an area where land is valued by the square inch.With millions ( maybe billions) of dollars worth of land for developers to use,it is only a matter of time before the airport is on the chopping block. Ultimately probably not all that bad in the end,as the Bay Area ( even the South Bay) is becoming a less and less desirable place to go to via any means. It’s too bad too,as SJC was a great airport in the 70’s.
