ADS-B data recorded by FlightRadar24 suggests the final 30 seconds of Metrojet Flight 9268 before the data stream stopped involved a series of violent dives and climbs reaching up to 8,000 feet per minute. In the last minute before the data ended, the aircraft was climbing normally at about 400 feet per minute before it suddenly dove at almost 6,000 feet per minute and then zoomed upward at 8,000 feet per minute. ADS-B data is not considered reliable enough for accident investigations and the real story will likely be revealed in the flight data recorder, which was recovered late Saturday. An in-flight break-up is a given but the cause remains a question. Early theories following the crash of the Russian Metrojet A321 in Egypt lean toward a technical failure rather than any sort of attack or pilot error, according to multiple sources quoted by multiple news services. There is also an unconfirmed report that a pilot reported a technical fault and said he was heading for Cairo. The tail of the aircraft landed far from the main wreckage and the plane did have a tail strike 14 years ago.
This is a companion discussion topic for the original entry at https://www.avweb.com/news/attack-unlikely-in-russian-a321-crash
